I hope this nasty winter ends soon for all of you living through it.
So, I have one of the most horrendous clutch rattles I've heard yet.
In neutral at idle it sounds like the bottom end is chewing itself up.
Pull in the clutch lever and it's better. Carbs are synced as well as I can get them,
so I'm going to try the GL1000 double steel plate swap fix. I've pulled my clutch
already and the springs and plates measure up to spec. Have any of you good folks done
this mod with good results? I'm waiting for the part to arrive. I guess after I put everything
back together and nothing has changed it could be the primary chains, but I can't pull
the motor so I might have to live with it......unless anyone has any advice????
I still have that loud clunk when I shift into first and second,
I was hoping it was clutch related but my clutch seems fine
so I guess my tranny needs attention.
thanks,
daren.
May your nuts never rust.
thanks,
daren.
