Clutch housing rattle
brettp
CB750 Guru
1,381
549
113
Florida
Good evening, all. I've never done a clutch rebuild so I'm in new waters.
While warning up the bike, I hear a rattle from the clutch housing. When I pull the clutch lever in it goes away. Is this a symptom of weak/worn springs?
Hey Brett. Is the noise worse after it warms up? You might have a problem with the dampeners in the clutch housing. Someone else had a similar problem on here but never heard back what he found. I posted this for him.
https://www.vintagecb750.com/parts/instructions/73-1131.pdf
Hey, Loose Chain.
No, I don't think it is worse. I think it is consistent throughout warm up and the ride. I didn't get a chance to ride today but I'll pay attention to that once I do.
I read the FSM and I don't see the dampeners mentioned at all. Where do they sit?
I know it's been a while since I posted my original question. The clutch rattle goes away (mostly) after warmed up and a ride. I think this started when I put Rotella in it. I know some people will say the Rotella is used by many people. I think I might try draining it and putting the 10W-40 motorcycle valvoline back in to see what happens.
Thoughts from others on the Rotella?
I really don't see the need to stray too far from what the manufacturer suggests. It's an alternative but it's not the holy grail that some people think. If you go on any forum, whether it's motorcycles, cars, boats etc, when someone starts a thread asking what kind of oil do you use, you get dozens of different theories. The oil that Honda recommends seems to work just fine.
brettp:
wondering if you solved this or whether its a problem at all. I've owned an 81 cb750f for a long time and it has had a rattling noise for a long time. not sure if it has always had it. same as you describe though. its more pronounced on start up when cold, lessens when it warms up, lessens when revs are increased, and also lessens almost completely when clutch lever is pulled in. did you ever find a solution?
i should add that I'm concerned now because lately it seems to be a bit louder.
I sold the bike, so i don't know it's current state. I did revert to 10-40 valvoline and it seemed to decrease the noise, but never went away.
There is a mod I was shown on this forum about the taking rivets out of the clutch basket (I think that's where they were) and replacing them.
