Clark204
Hi all,
I’m new to the forum and was hoping for some help. I recently purchased a ‘75 CB750 that had been in storage for some time. I got it running and rode it last year with no issues. I decided due to the year of the bike that I should probably update a few items, one of which being the clutch.
I purchased an NHC friction plate kit as well as a new clutch cable. I replaced everything carefully and made sure to soak the new plates in oil. Once replaced and fired up, I noticed that the bike now acts like it is in neutral even after put in gear. I have tried rolling the bike forward and backwards and nothing changed. I also have adjusted the clutch cable and lifter adjustment screw per Clymer specs as well.
My thought was that the springs for the clutch are worn out and need replaced. Do you think that could be the case?
