Valve depressor tool
ray_
53
Tampa
I want to buy a good tool for adjusting the valves on my DOHC CB750k. Is the OEM Honda two piece tool (07964-422000A) better to buy or the MotionPro "c-shaped" one?
I have used Motion Pro one without any issues. Just lube part that slides under the cam and use your common sense… works like a charm!
I've also used the Motion Pro tool for several valve adjustments. Just like Bo82CB said, make sure you lubricate it when using, but it works just fine. That Honda tool looks unnecessarily complicated (and probably much more expensive) for accomplishing the same job.
