Hello to all,
Im having a little issue in a 1982 Honda CB750 nighthawk, the bike run great and all of the sudden when i press the clutch and shift to first gear the bike jumps and shuts off as if the clutch is not disengage, I had check everything, cables, basket, adjusted the clutch according to the specs, at the handle and at the motors side, i even had replaced the clutch plates, new oil, springs are with in the specs.
at this point Im lost i had done everything that i believe should fix the problem.
All comments thoughts and advises will be well appreciated...
