Header install problems
WonWonrides84
9
Texas
What's going on y'all, I am extremely new to riding motorcycles and I have decided to rebuild a 1981 honda CB750C and I am having trouble installing the 4 into 1 header. I replaced the copper couch gaskets with some new ones. I tightened the exhaust mounts and I believe I installed the exhaust collars correctly,or did I install them backwards? But my header is extremely loose. I don't know if this picture helps. TIA.
Not sure from your pictures but the heavy gauge metal side of the two piece collars goes towards the engine. The one piece collars will have a gap between it and the cylinder head. It does look like too much thread sticking past the nuts, usually not that much thread sticking out after the nuts are tightened.
What's going on y'all, I am extremely new to riding motorcycles and I have decided to rebuild a 1981 honda CB750C and I am having trouble installing the 4 into 1 header. I replaced the copper couch gaskets with some new ones. I tightened the exhaust mounts and I believe I installed the exhaust collars correctly,or did I install them backwards? But my header is extremely loose. I don't know if this picture helps. TIA.View attachment 18040
Where do you get these pipes at. I had one fall off on the highway and it went into the ether
Where do you get these pipes. I have the same ones and one just chucked itself on the freeway and disappeared
another question, would y'all put new pipe joint collars on the headers or just clean the old ones. Walter
