frame change
chrisb26
batavia ohio 45103
hello my name is chris.this is my situation I have a 1980 750 that has no issues but has no title. I can get a 82 750 nighthawk frame I just need to know if I can swap it all over to it or do I need to get a different frame. help! what frames will for it. thank you.
The frame has to be one from the same model of bike, C, F, K, SC, or all the little bits will not go on. They weld different brackets and other pieces on what is pretty much a common frame to begin with but when done there are a hundred differences but all are small until you start figuring out how many parts don't fit.................
On the Nighthawk frame the tank mount pegs are different, the entire back loop that holds the seat and rear fender too. Side cover locators are different as well. Other things.
