Fork dimensions
dcm4u
California
Anyone have their forks off or in a position to verify some measurements? Im trying to fit up a fork brace and cant get the measurements myself for a few weeks.
Thanks.
You might do better if putting out there which fork you have and year, as they did change up there through the years a little bit. Some of the earliest may even have a separate screw-off sleeve right there where you have dimensions marked, and use a boot. Others will be a one piece leg with no boot and only use a dust seal.
A 71' K1 specifically. The lowers changed through the years in fender and brake mounts, internals too, but I think the upper part of the fork body (lowers not fork tubes) remained mostly the same through 76'. Maybe even later. Im not an expert, just my observations.
If anyone has measurements off of any year they have that would be helpful.
Thanks for the reply.
