Vicman
Hmm, would it matter front or back on the bleeder? Are the threads the same?
Wasn't sure DD.
It sounds logical like Grepper said, he might have a later model caliper for the opposite side of the wheel from a dual caliper set-up?
However I don't know the engineering on the insert.
I proceeded to polish the lowers.
Pretty standard polishing process. Paint remover to get clear coat off, then sanding with 220, wet 300, 400, 600, 800 grit. Then I have two polishing wheels on a bench grinder, first I use with Black compound, then the other with Rouge compound. Then I hand polish with Mothers aluminum polish. Lots of patience and elbow grease.excellent result, what procedure did you use on them ?
I like what you are doing. Do you have a fixture to check trueness and spoke tension?
Grepper, are you using SS spokes..?
