Blackzer0
I picked up a 81 CB750 custom with keihin vb-34sc carbs. after about 30 min. of riding the idle jumped to 6k. After some tinkering we noticed that one of the lock bolts on a sync adjustment screw was stripped (I hope the phrasing is correct). We took the carbs out and replaced it. Once we got it all back we hooked up the tank just to get some gas back in the carbs, we then took the tank off so we could make sure everything was working properly. While running we synced the carbs up and by the time we got them synced the carbs about ran out of gas (engine sputtered). So we hooked the tank back up thinking everything was good and then the #1 carb poured gas out of the overflow. Thinking that the float was stuck up we tapped and no change, so we took the bowl off, took the float off, cleaned the pen, reassembled and still it is overflowing. As of right now I am completely stumped on why this thing is dumping gas. Any Ideas would be great. Thanks.
