Greetings. First post new member.
I was gifted a 79 750K with around 35k km's on it. Its in factory configuration aside from a 4 into 2 exhaust system that is ok at best. The exhaust has no bypass.
The bike starts perfectly warm or cold and after a decent warm-up period, runs and drives nicely with smooth linear power. However at around 4000 rpm the exhaust note changes from smooth to a gnarly growl that sounds like its coming from 12 feet of plastic tubing. There's a significant power increase that's not so linear anymore and the engine becomes somewhat rough. At 4500 rpm it settles down and feels better but I think it should be smoother.
Question: Is this normal for this bike or does this sound like a jetting issue. Carbs were cleaned and synchronized a year ago but could likely use another sync. job.
Cheers.
Cheers.
