Swing arm bearing removel
BIKERDAD
86
21
Cardiff uk
Hi all I have a 1996 cb750fn2 P reg .
So at the moment it's being stripped down for power coating. So I taken thw swing arm off and got one of the bearings out quite easy undo circlip and use long bar to push it out. Well one side was . So iv tried to undo the 2and one the long bearing if tried to hit it out using long bar nope . So I checked again an again to make sure there was no other circlip nope. So I'm asking if any you guys had the same problem and how to do it .
There is nothing stopping it from coming out its just there is very little to hit to knock it out . Cheers
That sounds like the needle roller. Spray it with oil, then let it soak in. Maybe invest in a blind bearing slide puller, or a nylon or wooden drift punch.
Hi thanks for info I got them out over the weekend and tho the small one was bit fiddly I got the cir clip out and them it but the long one I had the bust it apart to get it out that was rammed in well . But both are out and no damage to the swing arm .
