neck bearings for front end swaps
RattyRatbikes
19
sacramento
Does anyone remember the website that had that 50 zillion mile long list of just about every tapered neck bearing used by motorcycles? If memory serves the site had a lot of blue on it.
I snagged a great Harley girder front end at a swap meet. Was going to have a stem made but the hand work on the stem mount is too beautiful for me to drill cut and weld.
I'm looking for the bearings chart so I can try to find the year that Harley had the same outer race diameter as the cb750 but still used the 1 inch stem.
OORR if anyone has a link to a kit for bearings that use the cb750 outer Dia. and 1 inch inner Dia.
Years ago I used a Yamaha dirt bike front wheel on an aftermarket Harley girder front end on a Triumph chopper I was building. I took the diameter of the axle and the diameter of the hole in the wheel hub to a NAPA store and they looked up a bearing set that was close. I ended up having to open up the hole in the hub a little bit using a Dremel tool, but it worked.
