Leaking fork at the top of fork leg??
kawtoy_77
24
Elliott, IL
I am familiar with fork seals leaking, but this is the first time I have ever seen a leak coming from the top nut/bolt whatever it is at the triple tree. What could this be? I checked to see if this was loose, but it is tight, so I am ata loss for why/what is leaking. Is there a seal at the top as well?
Think I found my problem..... O-ring at top of fork leg. Now my question is can I take off the top bolt without the spring shooting into the stratosphere?
As long as you have the front wheel off the ground so there is no pressure on the fork you can take the cap off. There will be a little bit of spring tension but it is not much.
