HELP!! I need a Vacuum slide (disphram) spring !
Leghorngarage
7
Jersey City, New Jersey
Hey ya'll
I'm a noob to this forum and need help. I'm rebuilding my carbs from my 79' CB750k and I'm missing a vacuum slide (diaphram?) spring. Part # 16050-443-701 as Honda lists it. The part is out of production and i can't seem to find one anywhere. Is there a replacement that i can use or is there a secret place i can find one? Please help the entire set is a paper weight without it.
Thank you!
Thank you for responding. Did that, did it on Amazon, did it on every website i could find. No luck yet...
From Partzilla for this part:
This Honda*16050-443-701 SPRING, VACUUM PISTON*fits the following models and components:
Honda Motorcycle 1979 CB750L A Carb. Component Parts
Honda Motorcycle 1980 CB750K A - 750 FOUR K Carb. Component Parts
Honda Motorcycle 1979 CB750K A - LIMITED EDITION Carb. Component Parts
Honda Motorcycle 1983 CM250C AC - 250 CUSTOM Carburetor
Honda Motorcycle 1982 CM250C A - 250 CUSTOM Carburetor
Honda Motorcycle 1983 CM250C A - 250 CUSTOM Carburetor
Honda Motorcycle 1980 CB750F A - 750 SUPER SPORT Carburetor Comp Parts
Honda Motorcycle 1979 CB750F A - 750 SUPER SPORT Carburetor Comp Parts
So, this should expand your field some. You might measure one of the others and compare to GL1000 parts, even some Honda cars.
try 4into1.com They usually have everything. Try their Ebay store. If you don't like the way it's setup. Try their online website.
