'81 CB750K Running brake light wiring issue
JMC
33
10
Texas
Hello Fellow Riders,
I have researched all over the forums and still cannot find a solution that works on my end.
My running brake light does not work in position 1. I'll try to make it simple:
Running headlight - works
Instrument panel lights - work
Brake light in position 1 with brake depressed - works
Running brake light in position 1 - does NOT WORK
Brake light in position 2 - works
I have checked the main fuses, cleaned all connections with contact cleaner and light brass brush to remove gunk/corrosion.
I have put new bulbs in the brake light, just in case that was the issue.
Of note, I do not currently have a headlight assembly, just the bulb. The wiring harness was new from vintagecb750 (the PO's harness had been altered just about everywhere).
See picture for my wiring configuration under the seat. I have "deleted" the turn signals.
Hopefully, this is a simple fix and I'm just oblivious.
Here's a better picture.
Ignore the color of wire in the middle. I created/soldered those using wires I had on hand.
The main wiring harness connections are connected to corresponding wires on the tail light harness.
There's a group of connectors stashed under the tail/brake light too, been the area of my bad connections a few times.
I was in there last night. Clearly 40 years of dirt, but I disconnected, cleaned, and reconnected everything.
Maybe it's a break somewhere along the brake line harness to the main harness.
Wires 40 years old turn brittle and break and ponch points. Not uncommon at all. That's why I suggested tracing continuity. I'm sure you'll find the culprit.
I agree but as I stated before, if ONE wire strand is good and all other broken you will still get GOOD continuity! True continuity test is voltage drop.
Just a thought, can you run new test wire if it is straight wire and not spliced one!?
That's a good idea, especially since I've deleted the turn signals anyway. I will try that.
I finally resolved this last week (and am kicking myself for it).
After all the connections I cleaned and locations I checked, it was the fuse box. I HAD checked the fuses, but the "brackets" that hold the fuses are a bit worn.
There's a sweet spot and the position of the fuse just needed to be adjusted up slightly. I couldn't believe it.
On the bright side, I learned a whole lot about wiring!
