For Sale - 1976 CB750 F1 Super Sport Motor and Carbs
BrettAvery
Turlock, California
I bought a project bike but already had a motor. This motor is a classic and an early super sport engine. If your looking to revive a legendary motor that changed the motorcycle culture and paved the way for todays superbikes...this is your motor!
The motor # is cb750e-2516970. It has good compression from what I can tell by turning it over. It has the kick-start lever and shifter on it. It has finned covers for the points and clutch covers. It is missing the stator, field coils and the connector gear (gear reduction) between the starter and drive gear. It is also missing the front sprocket cover. The stator cover is there, but it has a dent in the bottom and what appears to be a small crack. All other parts appear to be there.
That carbs are in good shape - would suggest a good clean and replace gaskets. All four carb boots are there and no cracks - seem to be newer boots.
Kick starter and shift lever are there as well and have very little surface rust. Clutch works - cable clutch is stiff and will need replacing...ran through the gears and found neutral easily.
Oil tank is in decent shape...a little surface rust on the back side but lines and hardware work fine. Will throw this in as part of the deal. This motor and carbs would make a great base for a custom build, full restore, cafe racer or bobber project.
Asking $350.00 for motor and carbs.
