Rear Brake pad change
kal-el428
71
Waterford, MI
Its time to change the rear pads on my 76' 750F and could use some insight.
I removed the cover on top of the caliper to reveal the pads beneath. There are 2 pins which run through the pads as well as some retaining clip between the pins.
How do I remove the pins? Do I need to remove the Allen head bolts on the inside (towards the wheel) to loosen the caliper so I can remove the pins?
I am sure its a fairly easy process, I just don't want to run the risk of damaging any of the hardware by trial and error.
Boy, I with they were a straight forward as the fronts :D
I am pretty sure you pull those hairpin clips, push down the rattle spring, and pull the pins out, slip the pads out, and the new ones in. reassemble
