Ricebiker
I can't get these carbs to stop leaking. Before you write about cleaning, and adjusting, and measuring, I've done 'em all. Twice. Wet test, aftermarket floats with bendable tabs, and different float needles(stoppers), (original floats were not adjustable and they were causing leakage then), cleaning with brillo and gun cleaners, pipe cleaners, acetone, carb spray, compressed air, etc. I also have a bog after 3/4 throttle. I thought it might have been clutch letting loose but it happens with the bike stationary as well.
So really, I think I'm looking to get rid of these carbs and just move on. After all, doing the same thing over and over again and expecting different results is the definition of insanity, yeah?
I'd like to get riser carbs instead of cv's. Are there any that y'all know of that'll fit easily? I'm not looking for $1000 set of carbs (CR's) I'm just looking for a set that will work on this bike and have decent power. If you've had experience in this area, I'd like to hear about it. i.e., a set of carbs from any other type of bike that'll fit right into the existing intake boots of mine.
80 CB750 F
Airbox, 4-1
80 CB750 F
Airbox, 4-1
