Evening all. I have just stripped my forks replaced all seals, clips and reassembled. The sta toons are now so stiff that I cannot slide them to the correct depth in the slider to be able to do up the bolt on the bottom of the slider to seal the units and then out the fork oil in. Is this normal or am I missing something? I have applied lube to the outside of thebstantion but even persuading it with a rubber mallet it does not want to move!!!
Any advice?
Thanks in advance
jsbarcs
Any advice?
Thanks in advance
jsbarcs
