mnvkngs65
Replacing the front fork seals and can't figure out what side faces down into the fork. Both sides of the seal have compression springs and have flat surfaces. The OD also appears the same on both sides. One side does appear to have 2 ridges/lips internally and also has a larger external gap. The other side has just one ridge and a smaller crevice/gap on the outside. I believe the side with the 2 ridges goes down???
Also, do I have to order copper compression washers for the bottom of the forks or can I use stainless compression washers I already have?
Thanks!
Thanks!
