750_cafe
Spring city pa
My 1980 cb750f super-sport has been a heck of a project, I have done everything needed cosmetically, and just finished the wiring not long ago, now all that’s needed is a tune. The bike tends to start, but can not stay running. I have messed with the carburetors enough to know it could be the jetting. I’ve had the bike running for tops 3 minutes at a time before it subsequently bogged down.
Note: choke needs to be on full for it to even turn over and stay running, sounds like it’s lean but wanted to hear from people with experience! Let me know what you think!
Are your coils hooked up to the correct cylinders? I commented on your other post.
I need the choke on at first start, even in Florida.
I have it set up like this
Coil 1 to cylinder 1
Coil 2 to cylinder 3
Coil 3 to cylinder 2
Coil 4 to cylinder 4
Hey brettp! Luckily as I was rebuilding this bike the coil packs and plugs were labeled with number coil, and number cylinder. Although that’s what they say I’m always gonna take it with a grain of salt, any idea what this could be?
First thing I’d do is pull the fuel line where it connects to the carbs, stick the end in a small can, turn the petcock on and make sure you have a good, steady stream of petrol feeding the carbs
Thank you for the advice motogrady!!
