Wanted - 18" rear reverse comstar
hi did you find one? i m looking for the exact same item for my cb 750C project...i hate that 16" rim...most of the 18 come with disc brake though!
The sprocket hub side is different as well, the C uses a 4 bolt sprocket, mounting hub, and rubber shock absorbers, the other one commonly uses 5 on them, lots of other parts need to change there.
Thanks a lot for sharing! Which model Is your 18 coming from? I guess It depends on that?
All 750/900 F bikes use the 5 bolt hub. The '81 and later is a little wider (2.50 vs. 2.15) but both are 18".
