DADDYG
DADDYG
HI guys
I am on the other site and offer HARNESS KITS and CUSTOM HARNESSES
HARNESS KITS are just the wires for you to finish up the way you want
THEY HAVE
3 WIRES FOR HEAD LIGHT HIGH/LOW/GROUND
3 WIRES FOR TAIL LIGHT RUNNING/BRAKE/GROUND
2 WIRES FOR BRAKE SWITCH HOT/WIRE TO TAIL LIGHT
2 WIRE HORN HOT/GROUND
1 WIRE FOR NEUTRAL LIGHT
2 WIRES FOR COIL AND IGNITION
Also can upgrade kit with TURN SIGNAL WIRES
CUSTOM HARNESS IS all the above but you can pick the way you want to run wires /USE YOUR
handle bar controls or I supply aftermarket ones. Just a custom harness the way you want it
ALL WIRES ARE COLOR CODED AND TAGGED 16 gauge wire is used 4 position fuse blocks used or I can
upgrade to 6 if needed . Can setup for electric start or Kick Only
You can contact me at DADDYGCYCLES@YAHOO.COM
Thanks
Rich
THEY HAVE
Thanks
Rich
