Pulse generator wire question
tommyoneleg
Johnson City, NY
My first post here, I have a 1980 cb750f, just bought it a little bit ago, has a sidecar on it. My pulse generator was bad so I put a dyna 2000 on it, everything is running but I need to find the "tach-input wire" on the bike.
On the attached picture the black wire goes to the engine but I don't know what it does and the green wire I have no idea about. I know I should have taken some pictures but when you get working you just forget sometimes and I have looked all over for a diagram but none found. If anyone can point me in a good direction so I am not walking in circle, a little joke.
thanks
Tommy oneleg
The little black wire in that diagram goes to the oil pressure light switch, which is on top of the transmission part of the crankcase, to the right side of the starter motor cover. The green wire goes down under the chain cover to the neutral indicator light switch.
