Turn signals on rear shock mount.
csherwood
9
Mesa Arizona
Does anyone know where I can find some turn signals that mount to the shocks? I just had a seat hoop welded on and now I don't have anywhere to put my turn signals. If anyone has other suggestions I am open to them!
i imagine that you would need to fabricate some sort of bracket that attaches to the shock bolt to mount the signals. that or weld a couple tabs onto the new hoop.
I took my stock turn signal mounts, drilled out the holes to fit over the shock stud, and then ground them down to about 2 shock washer thickness. The hope is that the mounting flange is thin enough that, in case the bike went over, the flange would break instead of bending the stud.
