Throttle cables help please
rbeesley1
7
elkin nc
DOES ANY ONE KNOW THE PROPER ROUTING OR BETTER YET HAVE A PICTURE OF THE stock ROUTING FOR FACTORY THROTTLE CABLES?
SEEMS I CAN'T REMEMBER HOW THEY GO AND THEY ARE THE ORIGINAL CABLES OFF THE BIKE.
THE JUST SEEM TO snap BACK THE WAY THEY SHOULD IN FACT I HAVE TO TWIST THE THROTTLE CLOSED TO SHUT THE SLIDES.
SEEMS A MITE DANGEROUS DON'T YA THINK???
PLEASE HELP ME OUT GUYS!!!!!
Check the return spring in the middle of carb rack, Check to see if the dampener screw below the twist grip is not to tight, Both cables route on the left side of the top frame tube if setting on the bike.
I just read Your separate post, If it snapped back before the carb removal seems like it has to be cable bind or return spring. The dampener is probably not the problem anyway it is between the throttle cables on the twistgrip.
