A couple of long shots. These bikes run off the battery, make sure you have good clean connections at the terminals especially both ends of the earthing cable. Make sure all cable connections in the ignition and firing circuits are clean and tight. Run the bike for a few minutes and check each exhaust header for temp, should all be hot, one cool one will narrow the problem down.
Check both sets of boots on the intake of the carbs for leaks or badly fitting. Pull the caps off the carbs and check the rubber diaphragms for cracks or tears.
Are you using the OEM air filter?
