Removing pressed in pilot jets
Use a 2-56 tap to make threads into the pilot jet. That tap size is close enough to start in the hole. Just thread down 3 or 4 threads. Some people use a sheet metal screw and screw it part way into the jet and then pull on the screw with a pair of pliers. The threaded way is better in my opinion because once the threads are there it is easy to pull the jets out if you have to do it again down the road. Your choice of methods.
