motogtp
1978 Super Sport, stock with clean carbs, 6,080 miles. Started running rough one day, like it was only on two cylinders and sure enough 2-3 plugs were sooty and 1-4 plugs were clean and wet. One coil was dead so I bought new plugs and the Cycle X optical trigger ignition and coil. Big difference! It has never pulled this hard before. However, the plugs are still black and sooty like it was running rich. So I thought, put on those air filter pods that you decided not to go with. That will lean it out a bit. No difference. Totally cleaned plugs will come out black and sooty after less than 5 miles of riding. I get a little blue smoke from the exhaust, but not much. Is it possible that I am burning oil and not running rich like I thought? Voltage regulator problem? Not sure were to go next at this point.
