ohnoitsmrbill
I just got a 92 CB750 and need to replace the handlebar as there is some rust on it. While doing so I thought about replacing both side controllers (starter, kill switch, turn signal, high beam) as they're quite worn. Do I need to disconnect the cables (Choke, throttle, etc) all the way down to the engine, or can the controls be replaced leaving the cables attached to their respective engine parts.
Thanks
Thanks
