I also found a lot of crud in the carb bowls when I drained them, wondering if this could be the source??
I pulled the bowls to check for more crud and there was a small amount. Whilst the bowl is off any chance of confirming if I have the correct jet orientation?
I'm now considering bypassing the air cut system due to corrosion in the carb where the plunger is meant to move, I could clean it up but I'm looking for a quick fix with no return work hopefully. Guessing I need to plug the lower left port where the o ring sits??
