Carb overflow
Gacataki
36
7
South Africa
Hi all, please help. I took delivery today of a 1980 CB750 Custom. The bike looks good, but I have one big problem. I open the fuel valve on the tank and everything is fine. As soon as I start cranking, the fuel literally pours out the back of all four carbs. I managed to remove all the bowls (on the bike), and if I hold all the floats up, I cannot blow into the fuel pipe. I put it all back together and it still does this. But only when I start cranking. The bike stood for 3 months. Please, I will struggle to believe that all 4 needle and seats packed up at exactly the same time.
Thanks I'll check. But could that cause fuel to run out the back of the carbs. Surely it would just drain straight through? Thanks for the help.
When you push the float up, your forcing the seal. Gasoline lifting them won't have that same force. Your float valves might need to be replaced.
I had that. Turned out the previous owner had put it eBay type floats (fully plastic, not adjustable). I replaced them with adjustable (plastic and metal) OEM substitutes from David Silver spares and that sorted it. That was on a 79.
Adjustable floats seem more reliable. But, if the seat is bad, it wont matter...seems that a float just floats, should control the flow of fuel.
Floats do just float. But if the tab holding the valve is off a bit, it can cause problems with not putting equal pressure on the valve into the seat.
Also we have the inherent fuel flow of these bikes. I think it's less than a 2 inch drop from petcock to fuel inlet on the carbs, that's not much fuel pressure pushing up on those floats. I always thought these bikes would benefit from an electric fuel pump, I'm soon gonna find out.
If you have a set from an '82c yes they will work. And yes you could use just the number 2 carb. If you have the set I would recommend rebuilding them and using as a set. Why do you just need the #2 carb? Is yours damaged? Just make sure you have all the correct jets to do 4 carbs. Your '80 carbs probably have pressed in jets and the '82 will have threaded jets.
