1980 cb750c build
mlbjb16
11
Ca
So I picked up a 80' cb750c a couple weeks ago
Started tearing it down completely was thinking about doing a single sided hard tail before I realized the frame is bolted together...I have autocad and solid edge experience so still might try and design a weld on single sided hard tail kit and sell it if anyone is interested let me know
I got it down to the motor and frame then proceeded to get the motor out of the frame
got the motor out of the frame and started sanding the frame and taking the motor apart...I must not be to lucky cuz I got the top end off the motor and one of the exhaust crank shaft bearing bolts broke off on my shouldn't be to hard to fix
I will add more to the build as it goes along...waiting on some cash flow to get the rebuild kit for the engine and gonna try and start designing the frame...does anyone know where I can get a full motor rebuild kit? How hard is it to rebuild this motor? I was in the navy for 5 years working on gas turbine engines so I figure it can't be any more complicated then that lol thanks for looking.
So I decided nothing crazy....funds and a new baby on the way made the decision for me! Lol but I'm doing a low cost cafe racer to flip and build another till I can get my funds right...
Here's what I'm thinking the stock cb750c 80 ride height is a little high in the front to get that signature parallel to the ground line so I wanted to see if I could do a conversion for a newer front end found a couple sites and if I send in the stem with the lower triple u could have a newer Gsxr front end for about $200 but in the rear I'm working my magic doing what I can with what I got...
I started this seat pan out of old scrap metal from me. Urging out my grille on my truck but it actually fits perfect! I used the stock mounting point for the front
These four holes with bolts run through work out great with the stock set up
so I cut off the original rear hoop seen here
Flattened it out and plan on using it as my rear seat bracket just have to weld into place
Then I will drill holes and add bolts accordingly then I will add the seat hoops in the back I picked up some 3/4" 90 degree tubing thought it would slide right in to exciting frame but the frame has a 1" and 3/4" tubing in the back as seen here
so I'll have to go back to Home Depot get 1" tubing and cut it to size and weld just can't decide if I wanna do a brat style seat with the stock hump in the frame or do a big hump in the back
Forgot to say I trimmed the frame 3.5" to fit the hoop and seat
This is trimmed with the seat pan on once I weld the hoop on I will trim the seat pan accordingly
So I decided to scrap the seat pan in the above pictures used it as a template for the electrics tray I did the full length of the back end
Still need trim and weld a little more you can see it on the sides
Then I proceeded to start the actual seat pan started with a card board template
ignore the other writing it was a GT suspension I was working on
Placed the template on some sheet metal traced it out now this part would have been much easier if I had/could afford the right tools to do it I have a grinder a vise some regular nail hammers one nylon hammer and a little mig got the metal shaped to size.
I am trying to be as resourceful as possible on the build so I am using stock mounting point and also using the stock brackets off the seat just modified here is the seat pan cut and bent into shape
I bent the front over the tank tail just to clean it up a little bit but like I said using the stock mounting points
got everything tacked into place and started welding and grinding
And there's she is
I am getting some taller rear shocks for clearance issues I also have some front gussets on templates tossing around the idea of relocating the ignition to there let me know what you guys think
Looks like it's been a couple of years since you've posted on the 1980 cb750c build but, I'm just wondering if it's finished or close and, what the seat looks like
