Yippy Kye Yay Neutral Sensor is in..)))
Bohnzye
78
Lorain Ohio
Ok, So a few weeks ago I posted in here looking for help on how to replace a transmission neutral sensor on a cb 750.. First of all this is not a cheap part, I called all over locally and got prices of $60.00-$100. I was fortunate to find a good used unit for $30.00 at a motorcycle recycling yard. Right now your thinking"this guy needs a neutral light to know when he is in neutral?" No I dont, But the problem was that the ball bearing that rides inside this sensor froze in the up position resulting in a continous oil leak wether the bike was running or not.. At least now you know there is no in between with this part. When it fails it fails. Vacuume can be a Mofo because after removing the electrical lead, and 10mm bolt and holding plate I commenced to trying to pry this sucker out and the harder I pried the more it resisted. I sprayed penetrating oil around the ouside of it and 10 minutes later I was able to pop it out. So far no runs drips or errors. 20120803_100658.jpg20120804_095845.jpg20120804_095825.jpg20120628_141245.jpg
