This is just great ... I'm doing the same conversion for my CB900F.. Thx..
I've measured the front hub to.. and I've come up with these dimensions..
The inner dimension of the conversion ring to Ø102mm (measured the wheelhub to be 100mm, but added 2mm for fitting)
Boltcircle Ø122mm (the above measurement plus your experience)
That seems to be correct - But I only checked it so far by calculating the distance between two bolts and then measuring it to see if it checked out and it did ...
I'll make some CAD-files and print them to scale to check if the measurements are correct - I'll get back soon
