LED Lighting conversion
I replaced the tail light along with all lights on the bike with leds, except for headlight, which I went with 7" housing with a 20/40w halogen bulb that lights up the road sooo much better than the old sealed beam that was in there. it's just the flasher when I got so low for draw that it wouldn't trip even the led flashers that I bought. Right now I have the resistors on the rear turn signals so that they are only used when turn signal is activated.
Dave I might have to try the led flasher you suggest, I did a little math when I put this all together and I had 200,000 milliamps on the 1 bulb, 250, 000 milliamps on the other and even less for the bulb in the dash and they failed to trip the flasher that I have that is rated at 2 amp minimum . It all worked (front turn signal, dash light and original non led rear turn signal) until I added the rear led turn signal and then it was to low for even the new 2 wire led flashers I bought . ( as soon as I put 1 led in the circuit the original flasher quit working)
The LED flasher eliminates the need for the inline resistors people put in to get the correct flash rate when using LED turn signals. The inline resistors use as much draw power as the incandescent bulbs did and so defeat the use of LED bulbs to lessen the draw needed for turn signals. The best way to convert to LED turn signal bulbs is to use a new LED turn signal flasher.
Hi all, I am trying to swap out stock front blinkers on my '81 750c with some slick looking motogadget bar end LEDs and the wiring is killing me. I got a diode that I haven't been successful in wiring up so I have a couple questions:
1. Since I'm only doing the front blinkers right now I figure I shouldn't go changing the stock relay for the whole bike as it will still serve the rear (does that check out?) so does that mean I need an individual load resistor on each of the new front blinkers? Any recommendations for those?
2. Do I need a separate diode that services the connection of each side to it's dash indicator light i.e. left to left, right to right?
3. Does anyone have a full wiring diagram of the front blinkers, switch, and dash indicator light that shows the scenario I'm dealing with? I've watched this video multiple times but I don't know if I'm understanding it right because it's not working (I could be doing it wrong): https://www.youtube.com/watch?v=4_QVSJZdUNY
Any help would be greatly appreciated! Thanks!
Hey guys
just bought an almost complete bike
the wiring harness is chaos so im just getting a new one from ebay. can i use oem harness with led lights? or is there something else i need to do other than upgrade flasher etc?
Hey guys
You only need to change the flasher to an electronic flasher to flash the correct time for putting LED bulbs in the turn signals.
Hey guys
So what bike did you get??
76 cb750 ( you can see in my profile pic)
so led headlight and tail works as should as well then?
Yes, nothing needed to change those, also the speedometer and tach bulbs all work properly.
Only the turn signals need a correct flasher.
thank you
i wonder if there are better solutions than oem wiring harness? im sure they will be spendy but just curious (i mean short of wiring it all from scratch)
thank you
Not other than a replacement harness made as for the oem harness.
What about the indicator bulb for the flashers would that need to be led. My issue is I have a diode installed and the left and right come and off with the switch but not flashing even with a led flasher. It has to be a faulty flasher right. Just trying to get a second opinion before I go spend the money on another flasher when I need the bulb as well
