Dave
CB750 Junkie
I'm planning to convert my lighting over to LED. All 4 turn signals and tail lamp. 1974 CB750k
My main reason for doing this is that the filaments break from vibration within days of replacing the bulbs in my front blinkers. Also, the LED's are brighter and the bulb I'm getting for the tail is even brighter and flashes 3 times before going steady when you hit the brakes.
The old flasher won't work with LED bulbs so you need to replace it with an LED flasher.
1157 LED Bulb X4
FL2-RED LED Bulb Electronic Flasher X1
1157 LED Bulb w/ Brake Flasher X1 <-- This has been discontinued. They now sell a box that will flash whatever bulb you use for a tail lamp.
PS I already run a Cibie Headlamp, possibly not legal in the US but who cares, so I'm not converting the headlamp. The shape of the beam provides higher visibility for me, and less glare to oncoming drivers. If you get one, they come in left or right, make sure to get the correct one for your area.
I forgot about this when I orginally posted. You have to do some modifications to the blinker indicator lamp wiring for this all to work or, just remove the lamp. I'm no artist but here's a drawing showing before and after I've added 2 diodes. I tore apart an old 12v adapter that plugged into the wall to get the diodes out.
Update, superbright LEDs now sells a kit for this single indicator lamp conversion.
https://www.superbrightleds.com/cat...ors/filter/Type,Motorcycle_Diode_Kit,60,6206:
1157 LED Bulb X4
