headlight problems
wright fox
11
Utah
I'm 100% newb, no experience at all. I have a 76 cb750. Bought last yr everything worked great and then one day the brights decided not to work. First I changed the bulb ( after checking the filaments which were good ) then while messing around there I checked all the wires tucked behind there. Fixed one bad connection but nothing. The only thing I can think is that it is the switch its self on the bars (oh I did check fuses too ). All other functions work, reason I'm thinking switch is because the horn doesn't always work unless you jab it a couple times, then it will start working. So I m thinking switch, how can I check and any other suggestions, thanks for any and all replies!!
