Or mount one of these on the front wheel. Take off the cable driven adapter from the wheel and mount this in it's place. Lots of options.
Okay this is perfect, haven't seen this option. That would be a great alternative to what I was asking. Can you send me a link to purchase one of these please? Much appreciatedView attachment 15009
You are welcome by the way.You are wasting both of our time, please go elsewhere.
I think if whitleyjacob went back to the beginning and read everything over again, he might realize I was trying to help him from the start. Only thing I was getting wrong was I kept calling a speedo a tach for some reason. It must be my old age catching up to me.You can’t fix Stupid - end of story.
With this type of sensor, I assume I can remove the front wheel, remove the original speedometer gear assembly, and replace it with this new sensor? Please let me know if it's more involved than that haha. I will make sure the dimensions are correct too. ThanksThe one that I showed you was just a sample. Check the dimensions to make sure which one will work for your application. And like I said, you could always use the one you already have
Sweet, sounds like a plan to me. I'll give it a shot, thanks guys.Yep, in essence that gear drive is also a "wheel spacer". Looks to be just that easy.
Edit There will be one thin metal part that is used to engage the drive. If they don't align correctly you can do damage and have a goofy wheel fitting. Not hard to notice and do right.
Pull the wheel off now so you have a clear understanding of how it all works. Then if you need to do any measuring to compare it to the type you want to buy then you have it right in front of you. But like I said, you could make the one you have work also.With this type of sensor, I assume I can remove the front wheel, remove the original speedometer gear assembly, and replace it with this new sensor? Please let me know if it's more involved than that haha. I will make sure the dimensions are correct too. Thanks![]()
Okay will do it tomorrow and measure. Appreciate it.Pull the wheel off now so you have a clear understanding of how it all works. Then if you need to do any measuring to compare it to the type you want to buy then you have it right in front of you. But like I said, you could make the one you have work also.
How did you make out?Okay will do it tomorrow and measure. Appreciate it.
