1982 CB900F KEIHIN Carb tune
Downunder Wonder
17
Oz
Chasing some advice on tuning the 4 KEIHIN Carbs on my CB900.
It was in storage for 5 years, and not running when I bought it.
Carbs needed cleaning, to get rid of the old dried up fuel. After that it ran, sort of.
Below 4500 RPM it coughs, misfires and splutters and has poor acceleration.
Confused
1000 RPM idle is lumpy and most time dies after a few seconds. Stays running if I set the idle up to about 2000 RPM
Mad
Hit 4500 RPM and it comes alive and pulls like a freight train.
Very Happy
Would appreciate any advice and how to tune for good bottom end performance
Idle problems can be from the pilot jets (wrong size, clogged) and carb sync. Mid range sounds like a problem with your needles and/or valve pistons. Are you running a stock set up?
G'day Brett,
Thanks for your reply.
Set up is stock. It had a 4 into 1 exhaust system fitted when I aquired it. But I also got the standard dual exhaust and refitted that. At the same time I got a carb rebuild kit, with standard jets and needles. Stripped and cleaned the carbs and rebuilt them with the standard bits.
I haven't tried balancing. So I'll look into that.
Would pilot jet needle adjust do anything for me? They are set to the standard 2 turns out from completely closed.
Needles are standard, and the pistons move freely.
Is there any sort of tuning manual where I could learn ore about these carbs? It's the first time I have seen KEIHIN's. Have worked with multiple SU carbs on autos, but this is 1st time on a bike
All of that sounds good. Your idle mixture screw is set well enough to at least idle. A poor idle that coughs and burps sounds like a carb sync to me. Do you have a stock air box or do you have pods?
Hey Brett, I really appreciate your help.
Air box is stock. Read the other day that this engine doesn't like Pods, but that's not the problem.
Put the vacuum guage on it yesterday, and the needle fluctuates wildly. Doesn't settle down to a steady indication. Same on all 4 carbs. Maybe leaky rubbers beteen the carbs and the head. But all 4 doing the same thing???
Okay, a couple things to go through here. Your carburetor sink vacuum gauges should have an option to reduce the vacuum on the line so the needle doesn't bounce as much. If it doesn't, you'll have to do your best to adjust the carbs so that the needles bounce within the same range. Now, the needles will bounce a lot at idle but as you give the bike throttle they should settle down. But idle is the real goal.
G'day Brett,
Took me a few days to get hold of a multi vacuum gauge set with adjustment screws.
I used it today and am really puzzled by what I see.
I have seen plenty of vacuum gauge setups on dual carb setups on various 4 cylinder cars, but this CB900 behaves different to anything I have seen before.
If it works I'll attach photos and a video, with sound on the video.
I have never seen vaqcuum gauges reading as low as what I saw today. I'm used to seeing vacuum readings around 50 on a good engine. This one barely gets above zero. 7 at Carb 1, 12 at Carb 2 (the reference Carb, 10 at Carb 3 and 5 at Carb 4. This with the engine idling at 1000 RPM.
Increase revs to 3000 RPM and I see a slight increase of around 2 on each cylinder
So I checked compressions. 120 to 125 on all 4
I checked valve timing. Correct as described in the Clymers manual
And I checked ignition timing. Carrect as per the manual.
All 4 plugs are clean, slightly black, so maybe a little rich, But not bad.
I'm waiting on a ColorTune plug, so I can see the actual flame color in each cylinder. Poor man's way of getting flame temperatures.
One other data point. On 3 recent 1-1/2 hour rides, moderately hilly country, cruising along quietly, not pushing it, It has turned in 45 mpg
The attached has photos of the 4 Vacuum gauges. Tried to post a video, but the forum won't let me.
  • CB900 Balance and Tune.pdf
Mine jumped around between 0 and 20. If the needles aren't moving much, I'd say the vacuum lines on the gauges are closed off or the valve adjustment is off.
You said the valves were within spec for the manual. Did you use. 003" or. 005"?
Hey Brett,
My reference to Valves and the manual was to say that the valve TIMING is per the book.
Not sure what you are referring to with the .003 and .005 numbers
Ah. I am talking valve lash/clearance. Putting feeler gauges between the cam and valve shims. If your valves are too tight they will affect your compression. In fact, they might be the number one variable to impact your compression.
Got it.
Hey, I really appreciate you taking the time to educate this "Newbie".
Cam covers off again and I'lll do some measuring.
Compressions are good, so I know the valves are closing properly. But too much clearance could lead to delayed opening, which ties with what the Vacuum Gauge labels are telling me.
Got it.
If your clearances are good, then you can at least check that off the list of things to check for any other reason.
If your vacuum gauges still don't seem to register the vacuum correctly, hard to tell if it would be the gauges. But that's where my mind would go.
What does the whole gauge look like?
If the attachment to my earlier message came through, there are 4 photos, on of each vacuum gauge. There are 4 identical gauges mounted on a backing plate. Each gauge has a rubber hose, connecting it to the associated cylinder. Each gauge has an adjusting screw, to allow closing off the vacuum connection sufficient to smooth out the needle vibrations.
I also have a single gauge, left over from my SU Carb tuning days. I used that to check each cylinder individually. I see the same wild needle vibration and when I squeeze of the connecting hose, I see the same low readings as on the 4 gauge set
They did come through. I was curious to see that adjusting screw.
Try letting the needles bounce a bit. As long as the cylinders are bouncing in the same range, you're good. Here is what I did:
1. Let needles bounce a bit, trying to make sure the bouncing was not wildly different than any other. Adjust a carb, blip throttle.
2. Ensure all bouncing in same range.
3. Rev to 2k or so and hold for a couple seconds, looking at needles.
4. Let off throttle, adjust where necessary.
Go to step 2.
G'day Brett,
Did all that you suggested and still had the engine stumbling and off song at low throttle. And a lumpy idle.
Did some more digging and found that #2 exhaust was cool to touch while 1, 3 and 4 would burn your hand. This with the engine idling after start up.
So off with the carbs again. and tear apart.
Initial inspection was that all looked good.
After a reeeeeeely careful clean of all the passages, particularly the slow jets, reassemble, refit, and crank it up.
#2 exhaust now hot. Yay!!!
Idle now much better. And good power low down when I rode it. Still not 100%, still a bit lumpy at idle and part throttle, but much better. It now pulls from idle all the way through to where it used to cut in and kick me in the tail.
I'll keep on tinkering and see if I can get that last little bit. I'll be happy if I can get a nice smooth idle.
Didn't want tyou thinking that I had grabbed what I could from you and then disappeared.
I really appreciate the time you put in to help me out, about a month back. Score 110 out of 100 for your assistance. Thanks a bunch.
Cheers
Glad it worked out! Great feeling isn't it?!
Now that you have #2 firing, you need to resync the carbs again. Sorry to say that.
Remind me, are your valves in order?
