shadowmoses42
I'm trying to remove my front hub so i can replace the wheel bearing and powder coat the rims. My manual doesn't go into detail on how to do this and it seems the bolt is very tight. My manual says remove the axle nut and spacer and then remove the axle from the other side along with the speedometer housing. My problem is the bolts seem to be very tight the whole axle twists in sync with my attempts to turn. Haven't found an effective way to hold one side still and turn the other. Any videos or instructions on how to do this?
