It is pretty much impossible to simply replace a bearing only and go back to it, the rod and crank generally get some type of damage there and often not visible to the untrained eye. but there to make it do it all over the first time you rev it up hard again. I'd say out of 100 engines then you can get away with it on 5. HIGHLY unlikely. I've done a few like that but most, no way, you will simply tear up engine again. Pretty quick.
Look at the bearing differences in the color codes. only like a couple ten-thousandths difference in each code to the next. Meaning maybe not even a whole thousandth difference in the entire color code range there and the engine wears crank more than that generally if it has lived at all. Making all bearing selection by color pretty much worthless. MEASURE parts to make sure but like we do on the DOHC, if parts are useable within wear limits then you generally use what will be the loosest bearing color you can get on all of the positions and thinking yellow IIRC in the case of DOHCs. The later year model may well work out to be the same way but careful measuring is in order, that will put the lie to the changing bearing only thing too.
They really pay close attention to new motor setup for max longevity but not really needed to run long and far if you can read measuring tools. Or Plastigauge.
You must split cases. Any rod that has spun a bearing is VERY highly likely to do it again. I don't care HOW good the part looks. Also, they generally spin for a reason, if not addressed then that underlying condition is probably there to spin it again as soon as you get it running. Odds are you may well find the other bearings to be severely worn too.
Rods have a weight code letter stamped on them; you match replacement rod with same letter as your other 3 to be same weight. Each letter has parts weighted to be within 5 grams IIRC. Read the manual. Don't be surprised if you have to balance rod, the older the engine is the more the lighter rods get bought to run out of those then nothing but super heavy ones can be bought and then you have to grind on it to bring the weight in line with the others or engine vibrates. I've had to match F weight ones to B's before. Grind city. Or find like ebay rod of correct weight.
Better hope crank not damaged like said, that'll end the party for a bit. Spinning bearing often tears it up and you can't regrind them like with cars.
