amc49
CB750 Guru
Try it and see but commonly the mounts change for every tank they use. The frames where tank fits stay the same but the front lug positions and the rear mounts change up both in location and type. 900C and 900F will be different from each other too. If an F then the tank likely longer by more than one inch, the K is forward enough to allow the side covers to cover the airbox sides, the F tank is long enough to uncover the airbox as more styling, likely way more than one inch involved in that. Can't say about 900C but I do know the 900C tank is longer than the 750C tank is, they do not interchange either.
Take old tank and find like 1 1/2" or 2" plumbing black cast iron pipe or even PVC and fit whichever seems to match the slot under tank better. Put tank in your lap upside down between your legs and then using a hammer then lay the pipe in the slot and holding it centered bang on the pipe (not the tank) lightly at first then if no result getting harder, you may knock that distorsion back out easier than you think.
