SHORT TO GROUND
Willishal
19
Bloomington, In
have 1980 750 C...got it o the point of checking wiring, hooked up battery and neutral light and oil light came on with no key in ignition. have been through about every wire and tested. what i know is that power is running through the ground system.. power at starter solenoid and one side of fuse holder...as soon as i hook up neutral switch the fuse blows and then i can pull the fuse the neutral light goes out. Is the starter sol. grounded through the new. switch..not sure where else to go....
Reply
Report
