rec tifier regulator combo wiring
rbeesley1
7
elkin nc
question guy's ; i am trying to wire in a new rectifier regulator combo into an after-market wiring harness
if the key is in the off position should there be power feeding the combo unit??
with the key ON and the engine NOT running should there be power feeding into the combo unit??
seems to be power into the unit always and it is draining the battery over-night.
there is also an aftermarket ignition switch which has a red,black.brown/white stripe and a solid brown.
i have looked at most of the wiring diagrams out there and none seem to fit this situation please help!!!!!
