Local honda shop can look up the bolts you need they are still available. Or go to a sight with online microfiche, Only two bots go all the way through the case, they are both different sizes. You can simply go to the hardware store and get bolts that are long enough and fit the hole size, they wouldnt have to metric because they are through bolts with bolt and nut and washer but one is a 10mm other is an 8mm if you want metric. All other bolts on the 750 are bolts that go into blind holes they are all 6mm. you will just have to get a caliper and measure hole depth and get bolts slightly shorter. nothing special about the bolts really, other then they are shouldered bolts.
