Help with Bars
bernie750
east hartford, ct
Just tried to set my clubman bars on the upper tree. They fit well but I want to use the stock electrics and master cylinder. With the Master Cylinder in place the bar end is too short for the stock switch which leaves the throttle tube overhanging the bar by several inches. If I rotate the MC downward so it clears the drop portion the reservoir is almost vertical, probably not a good thing. Does anyone make a bar with longer ends (don't know the proper term)
Thanks
Bernie
