Paulie
Texas
Hi,
New to the forum. I would really appreciate your help with this.
I bought a 1982 Honda CB 750 SC. Unfortunately the engine is bad so I have to replace it.
What years/models can I use?
Thank you in advance,
Paulie
Relatively new, but from what I've seen anything 79-83 should be a bolt in replacement, but the 900 through 1100 motors will require more and different work. Sticking to 750 would be the easiest swap. What's wrong with the engine you have?
It threw a rod. I didn't examine it closely enough at the time but it's definitely dead. So you believe that I should be able to swap in a 750k or 750F? Thank you
K, yes. Not sure about the F. I could be wrong but I thought the frame of the F was a bit different.
