Primetime63
Hello all, So I have this 78 Cb750k that I bought off an old man a few months ago and have found out that it doesnt like to start! When I test rode it at his house I noticed the engine was already warm. He messed with the idle srew on the carb and choke to warm it up..After I took it home it sat for a few days and on my 1st ride I burned the starter cylinoid up trying to get it to start!So I replaced it and then would drain my battery trying to get it to start! I know these old bikes with carbs and points can be tricky, so I checked the points and they seem to be gapped right, checked the valve gaps as well.. Now when I want to ride it I have to jump it off my car battery and it still takes a while! I also have to mess with that screw until I hear it want to start and then mess with the choke. Once it warms up it seems to run ok, but I have to constanty mess with the idle screw until the rpms get around 1000 or so..It will then start the rest of the day and even kick start, but after that its back to hell! Could someone tell me what else I should check? Im guessing carb rebuild? I did pull it and spray it down with carb cleaner when I replaced the air filter, but never synced them. Also once it starts it will rev real high and I have to push the choke down some..Im new to bikes as this is my 1st..Any help would be appriciated.
